Recently, I use the ORD U 4 to do a modeling project, and find several bugs.
AccuSnap function:
ORD usually gets dead when AccuSnap function is activated, for example, when creating a corridor and select the position, the cursor will automatically snaps the nearest element which is a reference file and including a lot of line elements, and if snap point is not what I want, I have to move cursor, but sometimes, ORD get dead when moving cursor over the reference element.
Linear Template tool:
If the model that is created by Linear Template tool need to be deleted, once click the delete button, ORD gets dead, and stop working dialog appears.
Besides, the key station can not be applied in the model that is created by Linear Template tool.
3D line style:
Everything is OK in MSTN Update 10, when copy the *.RSC file to its designated path of ORD, the 3D line style show nothing, but the 3D line style name can be seen in the line style selection dialog.
Exporting model to LumenRT Update 10
The Exporting model can not be done always successfully , sometimes, the 3D line Style element gets lost. before re-exporting, I have to zoom in the model close enough, and adjust view windows scale until the details(3D linestyle) can be seen, then the exporting could be done successfully, but I have to adjust view window many times, and do the exporting many times.
Hope you guys can checks these bugs above, and fix ASAP.
Looking forward to your reply!
Chen Zhengpeng
Hi Chen,
I also have very bad experiences with accusnap - ORD tends to crash out of reason when I hoover over elements that are in reference file. Usually it happens when I'm laying down geometry. What I do I usually turn off snap and locate option for my references. In cases I want to snap to a point from reference, I firstly draw simple line in active file that is snapped to reference element and then snap ORD geometry to it rather than to reference.
Hi Krzysztof,
It is a good workaround, thanks!
sometimes I also copy the reference element to activated DGN to get snapped.
I have the same issue with exporting 3D lines to LumenRT and it does not only concern Update 10 but also previous versions. I would guess it's a known problem. The "not elegant" workaround is dropping these lines into geometry (I think it was Drop custom linestyle tool). It makes the file a lot of heavier and you cannot go back (if you don't make backups:)).
And as for Linear Template removal there was topic 1 page back. Known defect:https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/159442/ord-u4-crash-when-deleting-simple-linear-template
Thanks a lot, now I can delete the linear template model bu removing rule. good workaround. But key station still can not be applied in the linear template model.
Have you Bentley team test these BUGS above? so far, no one reply me! what a pity! Besides, if you do not indepth use and test these software, you will never find these bugs! the test model should not be simple model!
