Is there any way to get annotation to show in front of civil geometry?
I've tried element priority, update sequence and bring to front with no success.
Josh
Hi Josh, can you provide some screenshots and the dataset?
Hi Marc,
Files attached.Annotation Files.zip
Hi Josh, what doesn't work? Do you have some screenshots?
Annotation over civil geometry:
Annotation under civil geometry:
Are the files 3D?
If so, the annotation may need to be "higher" than the linework. You can select it all, click the move command, select your starting point, and use the keyin XY = #,#,100 (or whatever number will get you "above" your geometry).
MaryB
