I am not able to create an interchange inn mx roads. plz can any none know how to do it in linemode and also by using options from the taskbar. plz can any one tell it in return formate or in a form of a video.......
See the following post - I mention an input file there that goes through the entire process.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/172365/mx-roads-ss4-interchange-design
sorry sir i went through that but i could not fine. is there any other way??? please suggest me in a form of a video if possiable
You want to see how it is done in linemode so what do you mean by 'any other way'?
Start a new project, and input the file "C:\Program Files (x86)\Bentley\MX V8i (SELECTSeries 4)\MX\MFW\xx_tut\thor105.inp" to see the results (where xx is UK in my case) .It will create everything from the ground model to the finished drawings.
okay sir
thank you go it
