Hi
I have a feature definition dgnlib from another Workspace Standard which includes some feature I need in my workspace.
But if I copy this dgnlib into my Workspace standard it corrupt (overide) all my setting like annotation for horizontal geometry and annotation group in my profiles.
Is there a way to copy feature definition between dgnlib?
I am using OpenRoads Designer Upd. 4
Sigfus Jónsson
Hello Karon,
Thank you for posting your question on Bentley Forum.
You can copy feature definition from one dgnlib to another. Please refer below the link for your reference.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/38083/wiki-how-to-copy-feature-definitions-from-one-dgnlib-to-another-in-project-explorer-in-openroads-designer
Purva Lakde
Answer Verified By: Sigfus Jonsson
I´m trying to do this, but it does not seem to work.I have modified my company cfg file.
A new configuration variable has been created.
But the Import/export options are not created.
Any suggestions?
Thanks!
Select the actual feature definition or category e.g. Geom_Temp, and then right mouse button - you have selected the file.
Thanks Mark, but it still does not appear.
Any other suggestions?
In 10.4, you can simply use the 'Copy' option from the pop-up menu.
You simply multi select several feature definitions and right-click copy from the referenced dgnlib, then right-click paste in the active file. This copies everything….Element TemplatesFeature SymbologiesFeature DefinitionsAnnotation Groups and DefinitionsThe only thing it would not auto copy would be levels so for those you would want to import those.
