Hi
I can´t rename a Text Favorite I have created. I rename it, but when I open the dgnlib again it has the old name again (0.00o/oo!
I have OpenRoads Designer Update 4
/Sigfús
HI Karon, yes I had the same issue. There is a schema change for update 4. There is a pdf in the organization-civil directory called workspace updates. On the last page of that page 20 it will tell you what you need to do!
Ross
Answer Verified By: Sigfus Jonsson
