GEOPAK Drainage - Design taking a long time at 80%
When I do a GEOPAK Drainage "Network Design", the progress bar quickly jumps to 80% and seems to hang there for quite some time. For the particular network that I am working on it takes 3.5 minutes to finish after getting to 80%. It feels much longer than previous networks I have designed with previous versions of GEOPAK. This is my first one with V8i. Is this normal behavior for V8i?
Thank you,
Josh Mauritz
  • Josh - The percentage counter increments based on large chunks of processing and not necessarily a linear progression.  So the first 10% might be for areas computation and next 10% for node calcs.  (no idea if those are reality just examples)  My point is that the counter indications pieces of comps and not necessarily a percentage of processing time.
    In my experience, yes indeed the counter does "lag" at 80% while the main and hardest part of the processing occurs.  3.5 minutes sounds long but perhaps not for a very large network.  One of my test datasets sticks on 80% for about 15 seconds or so.  This test network has 36 nodes and 35 links along with areas etc.
    How large is your network?
    Robert Garrett
    Senior Product Engineer
    Bentley Systems Inc.
