Recently I have noticed that if I have a line and want to trim to an arc and I use either the trim multiple of trim to element tool it will trim to the edge of the circle that is not visible.I am not completely sure when this started, it has been a few months. Where I work the company automatically updates the programs, I have no control over that.
08.11.09.878 Power Geopak V8i SS4
How is that arc generated? I just did a quick test in 878 where I placed a circle, then used the break element command to trim part of the circle to only give an arc, then placed lines that either intersected or were short of the new arc. When I did a Trim to Element is seemed to work.
Do you have a dgn you can attach or send to support so we can test with your data?
I just tested this on a coworkers computer in a completely different file. They have version 8.11.09.897 and it does the same thing.
