In previous versions of Inroads it gave the option for when creating the surface to exclude the triangulation as I can tell you in the version of open Roads that when generating the surface I do not believe the triangulation.
Hi Geovana,
Are you asking if you can create a terrain in Open Roads without triangulating or how to turn off triangles? If you want to turn off triangles, this can be done within Properties.
Sanders
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: when generating the Surface Exclude from triangulation
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
OpenRoads terrains are created differently from the InRoads DTM. In creating a terrain, if there is a feature or features that you do not want triangulated, do not add those features to your terrain. If desired, a 3D feature can still be displayed in your design file, or cross sections even, without adding it to a terrain.
Both options are available from the InRoads Explorer dialog box through SELECTseries 4.
