In IR v8i, why was the Define Transitions By (Constant/Length) toggle removed from the Horizontal Curve Set tools and left solely in the Options?
I used this toggle often since I have some alignments set by even length and some by even constant.
Can you please put it back, or add a toggle in the variable manager so I can turn it on if I want it?
Thanks.
Chris
Chris,
This was put in the options by customer request. Most users, use either/or in their definition of transitions. You can file a change request to have this looked at to change back or modify the functionality.
Thomas
Thanks Thomas. I guess it would seem ironic to have to put in a CR for something I already had in XM.
The default setting was still an option in XM. I don't see what harm it is having the toggles where they may be needed. It also served as a label next to the key-in to tell you whether it is length or constant.
