ORD Connect Edition LandXML import/export error and problems to/from InRoads SS2
I am trying to work with ORD CE (OpenRoads Designer v10.8.0.41) and InRoads SS2. Mainly to design and share alignments. I have no problems importing alg files from SS2 to ORD CE via import utility.
There is however peculiar error with LandXML import to IR SS2 from the ORD CE. The profile in the  is "wrong". The levels of the elements have different values, grades are different than the same points/elements in the ORD CE.
Three first elements of the same profile in ORD CE
Linear POB -600.000 200.514 0.020 PVC -333.050 205.853 0.020 266.950 0.000 0.000 0.000
Parabola PVC -333.050 205.853 0.020 PVT 480.950 207.074 -0.017 814.000 0.000 0.000 0.000
Linear PVT 480.950 207.074 -0.017 PVC 556.629 205.787 -0.017 75.679 0.000 0.000 0.000
the same elements after import to IR SS2 from LandXML
Element: Linear
Poczatek opracowania -6+00,00 200,00
PŁP -3+34,00 205,14
Tangent Grade: 1,932%
Tangent Length: 266,000
Element: Symmetrical Parabola
PŁP -3+34,00 205,14
W 0+73,00 213,00
KŁP 4+80,00 206,73
Hmax 1+18,73 209,51
Length: 814,000
Entrance Grade: 1,932%
Exit Grade: -1,541%
r = (g2 - g1) / L: -0,427
K = l / (g2 - g1): 234,374
Middle Ordinate: -3,534
Element: Linear
KŁP 4+80,00 206,73
PŁP 5+56,00 205,55
Tangent Grade: -1,541%
Tangent Length: 76,000
Almost all parameters are different. Can anyone explain this?
Secondly the ORD CE crashes constantly on import from LandXML.
