I would like to ask how to create a template of this end condition where the slope changes and the bottom part of the end condition has a variable height. The top of end condition is fixed to be 4.5m from the existing ground.
I am using InRoads SS2.
Thank you.
Ron
Try breaking it into two end conditions. The first end condition should catch 4.5m from the existing ground surface using the vertical offset found in the component properties. Attach the second end condition to the first, targeting the existing ground surface.
bench.itl
Thank you Ray, That is a good idea using a vertical offset. I have not used it before. I shall give it a try.
I really appreciate the ITL file you sent. I see where you have set -4.5m offset vertically from active surface.
Thank you once again.
Ray, I do have a follow up question. How would i go about computing the volumes of layers of soil(3m), weathered rock(1.5m below soil) and weak rock(below remaining layers).
Here is a link to the files.
https://drive.google.com/drive/folders/1u6WAJ603FHXzPY-tc5Al08iOcB5Jk90j?usp=sharing
I have looked at project to surface solution but not sure yet how it can achieve my goal.
No worries Ray, I think have a solution already.
