I have an ORD terrain mesh that is 800Mb. What tools can be used in ORD to reduce the file size?
I Geopak in the old days there were tools to thin TIN files?
I undestand that the accuracy of the terrain mesh will decrease but that is not an issue.
Ping...
Hello, any follow-up on why I don't see the filters you show?
Sorry for delay - the option is only available when you use Import formats dealing with points, such as
Details about thinning can be fouind in OpenRoads help file.
So you would need to export your surface in one of these formats, to have ability to filter importing back the points.
Vincent RAULT [Bentley]
Did you miss the OpenRail webinar? It is on demand at https://pages.info.bentley.com/video-details/?video=CO_VID_ORBIM_0318&videoDBID=a9cba4bc-d461-45ef-94d1-0072055fee9a Drift Boss Our next Tech Talk is Wednesday March 21: Tech Talk: How Configuration Management Supports Positive Train Control. A key element of positive train control is managing information related to the rail network and trains. This Tech Talk discusses how AssetWise helps enable PTC deployment and provides best practice configuration management and information integrity in a changing environment.
Hello Martin,
I don't know of a practical way inside ORD to simplify existing mesh but there are things you can do outside. In some existing maps, for example, contours can be drawn as bsplines. Converting them to linestring linetype with custom sensitivity significantly reduces the terrain size in ORD. Actually, I don't understand why bspline contours are solved with so many triangles in ORD. If at least the minimum distance between the mesh points can be determined, we can create a terrain surface that works much easier and faster. In your case there may be a similar unnecessary triangle formation. Can you share a sample screenshot of your Terrain mesh?
Erdem
