This might not be the appropriate place for this topic but since it is dealing with cross sections it is kind of relevant.
I have set up a .pset file and using print organizer to plot aprx. 80 cross section sheet files. After hitting print it is taking over 3 minutes to process a single sheet. Does anyone have any experience with this? Why would it take SO LONG to print a single sheet? The older batch plotting routine in v8i was MUCH faster.
What am I doing wrong???
Marc
ORD 10.4/MicroStation Connect
Just to make sure - is the "Rasterized" option set to on or off?
MaryB
I have the same problem. Takes 10 minutes to print a 2 page PDF with aerials.
Here are some advices
https://communities.bentley.com/products/microstation/w/microstation__wiki/51580/taking-a-long-time-to-print-pdf-in-connect-edition
jing jing (o'.'o)
