I know that with OpenRoads Connect, Bentley has chosen the Ribbon bar for access to tools. But if you turn on Task, then You dont have access to the Openroads Modeling tools + OpenRoads Drawing Production and Sunsurface utilities in Ribbon or Task bar is that correct?
And it also applies to other Bentley products You dont have access to all tools. I can see in Microstation you have access to everything in the Ribbon and Task bar.
Why this solution? If you bet on the ribbon bar you should not have access to the Task bar. I know that habits and routines are hard to change and there will be a lot of trouble if you remove the task bar 100%
Hi Johnny
I'm not sure i completely understand what you mean here ? HOw are you turning on Task ? Any chance you can add a few screen grabs to show what you mean ?
Simon Pegg
Bentley Civil Support
Are you referring to the Task Navigation Workflow found in MicroStation?
Or do you mean the ability to turn on the legacy Task Dialog as described in:
https://communities.bentley.com/products/microstation/w/microstation__wiki/24481/how-to-display-the-v8i-style-tasks-dialog-in-microstation-connect-edition
MicroStation is the only product that uses the Task Navigation workflow and is not available in other MicroStation based project.
Thank you for your response.
I attach just a few screan grabs.Does it have anything to do with one's Workspace and Workset setup?
