I'm trying to create a sheet seed for creating a profile drawing, but I'm having problems with the named boundary. When I place a named boundary, all seems to go well until I click to accept my named boundary. Instead of the Create Drawing window popping up, I get a "Group Unnamed Profile not found" error on the message centre. Any ideas on how to sort this one out? I'm using OpenRoads Designer Update 3.
Does the path to your file or its name contains any period, comma or any special character?
No special characters in the file name or file path. I've also tried creating a brand new Plan or Profile Start Seed file to use for my sheet seed, but the error is still happening.
Can you upload your dataset at the link below, I'll investigate it: https://bentley.sharefile.com/r-r49aba1bd8a945499
Hi Mac. I've uploaded my start seed file. Let me know how you get on.
Thank you, can you send me your Configuration values? You can find it here: File / Settings / Configuration / Configuration Variables > File / Show Configuration Values.
