I'm trying to create a sheet seed for creating a profile drawing, but I'm having problems with the named boundary. When I place a named boundary, all seems to go well until I click to accept my named boundary. Instead of the Create Drawing window popping up, I get a "Group Unnamed Profile not found" error on the message centre. Any ideas on how to sort this one out? I'm using OpenRoads Designer Update 3.
Does it work if you try with a different workspace or different folder?
It works with a different workspace or a different folder.
Marc. I've managed to sort it out. I just binned my organisation level workspace, and pulled out my backup version. But one other question related to Named Boundaries. Is there a way to set assign a feature definition or element template to the boundaries? At the moment they are drawn on the Default level.
Thanks for letting me know.
Good question! I don't think you can modify the level in which it is created, you might change it manually after. I'll have a look at it.
I am having a similar problem in ORD Update 4. After I create a named boundary and a drawing model is not created even with the create drawing option checked. Then if I try to create the drawing it gives an error that it can't find the group, but the group is in the named boundaries dialog (see screenshot). I have attached the config variables for the workspace. What configuration variable could be causing the problem. I am working on ProjectWise so I would rather adjust the workspace than export locally and use a different workspace every time I need a section. Thanks.
log.configVariables.txt
