Power InRoads - How do I get Read-Write access to the alg file?
I went to File -> Project options -> Geometry.
At the bottom it says Default Access Modes --> Read-Write.
FYI I downloaded my alg from projectwise. (Save as --> saved to my local drive)
Thank you!
Parents Reply
  • ProjectWise Explorer? that has icons and/or menu items to update or check in files that you have checked out. If you actually copied it out to your machine, it may not be that easy. Your ProjectWise Administrator probably has some sort of guidance on how they expect you to work on files in their project. If they don't , they should.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
