I went to File -> Project options -> Geometry.
At the bottom it says Default Access Modes --> Read-Write.
FYI I downloaded my alg from projectwise. (Save as --> saved to my local drive)
Thank you!
ProjectWise Explorer? that has icons and/or menu items to update or check in files that you have checked out. If you actually copied it out to your machine, it may not be that easy. Your ProjectWise Administrator probably has some sort of guidance on how they expect you to work on files in their project. If they don't , they should.
MaryB
