Is there any way (Keyin, dialog, other) to give a data point at zero offset, profile grade elevation?
Yes, I am aware of the SE= precision keyin. I have to know the profile grade elevation already in order to use that.
I am hoping (against hope!) that there is some way to get the profile grade elevation for a known station while in that cross section(!) and use it to place an element.
Geopak had a great tool for this, but I am, unfortunately, no longer working in Geopak. Does InRoads have anything I can use like that?
MaryBPower Inroads 08.11.07.615
Let's simplify this. Forget about my cross section. Forget that I said I was trying to draw ANYTHING.
My engineer comes up to me and asks me what the profile grade elevation is at Station X.How do I get him that information? How many steps do I have to take (and what are they) to answer this question?
MaryB
Set the alignment active. In Plan view use the tracking tool. Tools>Tracking>Horizontal Alignments. Snap to the object and the readout will give you station, offset, grade, elevation. (the grade and the elevation values correspond to the active profile). If you don't have an object to snap to, draw a line or place a cell with the command so= (station,offset).
Answer Verified By: MaryB
Are you sure the elevation is the Profile and not the active surface?
Yes, If you use the Horizontal Alignment tracking it is the active profile. I also like setting up an InRoads note using Station and Vertical Elevation.
That's the most concise solution yet. Thank you.
