In OpenRoads Designer (2018 Release 2) The table editor will only show Spiral Length – not the parameter.
Is there any way to add a column showing the clothoid parameter?
Secondly; when using the Design Standards and Complex Geometry By PI, the dialog is very reluctant to show A-value instead of Length. It changes back to Length all the time.
Thirdly; the typed in value (being A-value or Length) shows as the manipulator value. Is there a way to always show the A-value (or Lenght)?
There is not a way to add a column to the Table Editor, this is a technology preview so it is the first version. Perhaps we can add this functionality to a future version.
As for the second item I have not been able to reproduce this as of yet. My dialog stays the same.
As for the third item are you asking to show the label of length or A-Value instead of the numeric value.
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/27341.openroads-training
Thanks, Beebe.
As for the first item - how do I create a change request? In Danish road design we only care about the clothoid parameter, not the length (as oposed to Danish rail design).
As for the second item - strange...
As for the third item, I'll give you an example:
If I create a curve with back transition defined by clothoid A-value=250 and ahead transition defined by clothoid length=110, those are the numbers shown. But in case I want the A-value (256.90465) shown even thought the spiral was originally defined by its length, how can I do that?
