Hi Guys,
I used to work in Microstation Powercivil SS2 before for importing my survey information. I used to upload all my raw data from my total station to Powercivil SS2 through Survey<Dataset<New and upload my .csv file into it. It used to create spot elevations as a text into my survey plan.
Unlike from Powercivil, when I started using Open roads, I would create a fieldbook and click on import text wizard and upload my .csv file here which directly creates a terrain model. But it doesnot create a text for the elevations. I tried to create it through terrain spot feature but I am not able to copy the elevation text in each spot. Is there any way to import the elvations as a text?
Thanks.
-Jenish
Hi Jenish,
this is MicroStation forum, so it's not recommended to discuss "civil issues" here. I recommend to move you question (please DO NOT create a new one!) to civil forum. You should find Move tool in More menu.
With regards,
Jan
your query has now been moved to the OpenRoads Forum
