Export Open roads file to AutoCAD
Since our client demanding AutoCAD out put files, I was trying to export cross section and profiles to AutoCAD from Openrads. I tried all possible ways but could not get a proper output. You guys have an idea Is it possible or any proper way which I have not tried. I have asked this question to some of Bentley guys unfortunately they could not comeback with a solution. If it is not possible, then there is no use for me to use Openroads software and go back to PowerInroads which does quite good.
