Since our client demanding AutoCAD out put files, I was trying to export cross section and profiles to AutoCAD from Openrads. I tried all possible ways but could not get a proper output. You guys have an idea Is it possible or any proper way which I have not tried. I have asked this question to some of Bentley guys unfortunately they could not comeback with a solution. If it is not possible, then there is no use for me to use Openroads software and go back to PowerInroads which does quite good.
With the last update, we have managed to export sections in dwg.
These are the steps:
1.-Variable: MS_REF_VISEDGE_ATTACH_STATE = CachedAutomatic I saw this in a post, I think of Mark Shaumon, thanks.
2.-Save the AS options:
This is the drawing in dwg:
I hope it helps.
Thank you
Sorry for my english
Sorry, it's not save as, it's exporting to dwg
Sorry I did not understand the first step. Please make it clear to me
thanks
shanas
Hello, Marcus
Exporting to a DWG file, right now, has become a workflow that takes a lot of time.
It would be great to develop a tech talk about the workflow to export to DWG format and inform about future improvements.
Mauro Vega
Settings
Confinguration/ Configuration variables/ MS_REF_VISEDGE_ATTACH_STATE change Dinamic for CachedAutomatic
