Hi guys,
I'm trying to set up some standard ORD DWG export processes for my organization and have only found a few methods to get the outputs I require without issues that require extensive post-processing to be good enough for delivery. Plan exports are a bit convoluted to get past the issue of elements exporting with no symbology after splitting strings with gaps during export, but it gets us close to what we want - unfortunately many issues regarding annotation values changing on export. Ideally i'd love us to be using Microstation to take advantage of the native dynamics, but unfortunately our market is primarily AutoCAD for drafting.
Here's what i've come up with so far using ORD 2018 R3;
*UPDATE* - A few improvements in ORD 2018 R4 meaning less custom processes
*UPDATE* - More improvements in ORD 2021 R1 and R2
2D Alignment Plan export with Annotation - process required to export chainage annotation:
Steps:
1. Open new DGN using 2D seed
2. Reference in Default model with no nesting
3. Turn off display of unnecessary levels
4. Create Fence around data
5. Deactivate Auto Field Update using "EXPAND SET MS_AUTO_UPDATE_FIELDS = NEVER" keyin
6. Use Fence to File command to copy contents to new DGN
7. Open New DGN
8. Select all Annotation Cells (named "DrawTextAnnotation") and drop
9. Select all Text Nodes and drop (this seems to allow correct export of field values)
10. Export to DWG
11. Reactivate Auto Field Update using "EXPAND SET MS_AUTO_UPDATE_FIELDS = ALWAYS" keyin
Note: You can start the process from your live DGN Default (2D) model and skip points 1 and 2 if you don't mind changing many level display settings in your live file. We keep a DGN saved for export levels already preset.
3D DWG Plan export - process required when model includes string gaps and clipping, etc.: Normal DWG export is now resolved, although this process gives a cleaner result (WYSIWYG)
1. Open new DGN using 3D seed (or 2D for flattened DWG)
2. Reference in Default-3D model with no nesting
5. Use Fence to File command to copy contents to new DGN
6. Open New DGN
4. Select all Complex Chains and drop (required to avoid dropped chains being put on layer 0 by default)
5. Export to DWG
Note: If you want a 3d DWG and don't mind changing many level display settings in your live file, you can start the process from your live DGN Default-3D model and skip points 1 and 2. We keep a DGN saved for export levels already preset.
Cross section DWG export :
*Required DWG Export options:
Note: MS_REF_VISEDGE_ATTACH_STATE = CachedAutomatic config variable doesn't seem to be required anymore - correct me if im wrong?
Issues:
Profile DWG export:
Mark
Thanks Mark for your contributions, personally they have helped me a lot.
Unfortunately, many local agencies and clients work on the AutoCAD platform, so it is important that ORD optimize this workflow because it currently presents several issues.
Mauro Vega
Hola Stomik,
Nos podrías compartir tu flujo de trabajo.
Gracias.
Saludos,
Export to dwg save as I get error.
These are the steps:
1.-Variable: MS_REF_VISEDGE_ATTACH_STATE = CachedAutomatic I saw this in a post, I think of Mark Shaumon, thanks.
2.-EXPORT options:
this is the result.
Sorry for my english
Make sure to set the References > External Attachments setting in DWG Export options to "omit". There are sometimes issues when it tries to export references from the 2D and 3D models.
