Removing Item that appears in Flex table but not in the drawing
The conduit does not exist in the drawing but is still showing up in the flex table and causing an error int he computation. Is there a way that the phantom pipe can be removed?
  • I am now having this issue with a model that I created from scratch. I am using OpenRoadsDesigner v10.13.2.2 and the NCDOT workspace. The conduit does not have a start node or stop node, they must have been deleted without deleting the conduit. It shows up in flex tables as well as the notifications after a failed compute, however, it does not show up in the project explorer. Is there a way to manually edit or delete this element from the system?
