Hi all,
Because I couldn't wait for an out-of-the-box "synchronise all templates" functionality in ORD, I have put together an mvba that crudely will synchronise all or just edited in-place Template Drops and Linear Templates. It seems to work quite well so far. Thought i'd share as it seems a shame to keep it to myself...
What it does:
MVBA Options:
In order to avoid the "Are you sure" dialog that shows when syncing a Template that has been edited, the mvba needs to locate where you put the SendKeys.exe app. The location (path inc. trailing "\") of send keys can be defined by adding a variable named "SENDKEYS_PATH" to your workspace / configuration (I have also defined other locations we use locally)
If the variable is not defined, the macro will still work, but it will pause with the dialog and wait for user input.
Happy to get some feedback if anyone finds any issues with it...
ORD_SyncAllTemplates_mvba_v2.2.zip
Thanks, this can be a great tool! However, I get the following error message:
Any idea how to solve this error?
Hi Merlijn,
Are you in the 2d model where the corridors are?
Mark
Hi Mark,
Yes, I am. There are multiple corridors with template drops, so it should work.
Kind regards,
Merlijn
I have just updated the zip in the original post to reflect the latest version. Changes include:
Not sure what issue you were having, but hopefully fixed in this version.
maybe your Template Drops aren't on Construction class? To keep scan time down for large models it only scans elements on Construction class (as they are by default in the delivered Feature Definitions)
