I am using Open Road/Rail Designer connect edition creating complex PI method .I have one difficulty that as normal after after PI it display radius option but in my case radius option is not showing.What can be problem not showing automatic radius option in complex PI.
Om
Hi Om,
Did you ensure that you are selecting the correct command?
Sanders
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/35109/ord-geometry
Hi
Thanks for your reply and video.I have selected right command but it create line and join it.It don't show any curve in-between two elements. In your case automatic coming curve but in my case donot show any curve option.
https://we.tl/t-YAfDiYRnh6
This is my video Link which donot showing Curve by using complex PI.
The length of the straight in your video is less than 0.1m whilst you have a curve radius of 200m so any curve that would be displayed would be far off the screen. If your straights are a reasonable length for the curve to fit between them then it should work fine.
Hi Mr Paul,
Thanks for reply.Even I am taking bigger Straight Length and Small radius still I have same problem.I think that I need to learn any adjust or setting for PI or Element .I have search that I donot find it.
I also just noticed that you are working in a 3D model. Please create a new DGN using one of the installed 2D seed files and the geometry should work ok. Horizontal geometry should always be created in a 2D model.
Thanks Mr Paul thinking about my problem and providing new answer.Actually I have tried many times in 2d Seed Design Model also It has still same problem.Just I was wondering is there any setting for element or PI.
