How did I get two 3D models associated with my 2D model in SS4 and what should I do about it?
This should not be possible. If you do get it I would say the file is FUBAR!
Answer Verified By: Keith Kennon
It was weird because there were old remnants of the corridor that I was able to delete, which is normally not possible. And the model was not updating correctly. Then, I noticed that there was a new model named Default-3D-1.
So I blew it all away and started over. That worked!
That is actually possible, just happened to me.
