I'm pretty new to try to annotate cross sections with OpenRoads tools in GEOPAK. Currently, I am able to get the offset and elevation values for a specified point on my cross section, but the text appears too high on the sheet. Where are the parameters that affect this, and how can i bring these numbers down to the correct position.
What software are you using?
OpenRoads with Power GEOPAK
Which one? OpenRoads or PowerGeopak? They are two different packages. Could you include the version number, too (there have been several releases of each)?
MaryB
You mean the OpenRoads Technology tools inside of GEOPAK, not OpenRoads Designer, right?
yes. So I guess GEOPAK is the main software
