Hi
Suddenly I can´t change elevation of vertical geometry by keying in. Nothing happens when I do so. But if I keyin a slope, the geometry response.
Anyone with a clue why?
If I create the Vertical Geometry and use the Toogle snap, the elevation is locked and can´t be change manually with Key in, but if i create it without snapping i can change elevation manually
(PowerCivil has not this problem)
I am using ORD update 4
/Sigfús
Could it be that by snapping, you are creating a rule which locks the elevation to the snapped point?
Hi Mark
I think i have found why start and stop points of the vertical geometry is locked.
If I use "Key Point Snap" to start and end oft he geometry in the profile, the end become lockd in elevation. It dos nor matter in between where two geometry elements connect.
How ever if i use "Near Snap Point" as a start for the geometry and ending will these points not be locked and changing of elevation by key-in is possible.
