I have a surveyor supplied survey data in the form of an Autocad file. The terrain model is represented by 3DFace element.
The surveyor can't generate genio or LandXML of the terrain.
What is the easiest (and accurate) method of creating a terrain model from the 3DFace elements?
Thanks guys. Success!
Tried it and it worked. Much improved on old MX.Maybe the cleanup (thanks jpin) made the difference.
Hopefully in future, I can continue to get LandXML or Genio files negating the need to do this manually.
