i found no video to add data bands like design levels existing levels level difference stations super elevation horizontal & vertical geometry etc in profile view is this possible to add data bands in profile view like civil 3d???
Yes it is possible. You need to set up an Annotation Group that defines what it is you want to display. The Annotation Group would normally be stored in a DGNLIB. The attached XML file can be imported into the Annotation Group Manager to give you a starting example.ProfileSuperEAnno.xml
This may also help.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/38044/how-to-create-a-profile-frame-annotation-group
Hi Mark,
Have you by chance found a way to make the title box longer so that the title text fits inside? Seems simple enough to make the box taller by adjusting the frame "Row Height" but I can't figure out a way to make the title box longer. One image attached. Thanks in advance!
