when i cut a section , the 3D model reference is attached whit a smoth shadow presentation, i have to change the properties of the reference and reload it to get a wireframe presentation.
thank you
Hi Steven,
Can you just go to your view properties via the right click menu and change your view presentation from there?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
the view presentation is set to wireframe (changed that in the dgnlib for sections), now it's automatic, the view is made with wireframe display. But i still get the smooth shadow in my cross sections.
it's because the refence presentation is set to smooth shadow. (rigth clik on the reference in the reference window)
and i can't find a way to do this but manually on each section that i make. i have tons of sections to produce.
it take a lot of time to open the view model, change the presentation properties and reload the reference.
is there a way to set that presentation automatically to what i want instead of doing it manually ? a variable to set, a dgnlib to modify ?
Thank you
What about trying to delete your Dynamic Cross Section and regenerating.
Use the keyin: geometry dynamicsection deletedxsviews
I'm having the same issue except its set to Transparent - did you ever figure out a workflow for this?
Have you tried Mark's suggestion?
MaryB
