I have created a corridor and now wish to have the template follow some linework that is not at a default distance that is coming from the template. in the template, in the point menu I have added the feature definition I wish to follow. when I try to add the linework as an external reference I get the following message "invalid 3d element-child of corridor". the linework is in a separate file with the correct feature definition and that file is 2d. do not understand the message. thanks for your help, brian
Hi Brian, can you share your dataset? You can upload it here: https://bentley.sharefile.com/r-r0befa184c2a4abda
Glad it works now.
Which version of OpenRoads and ProjectWise do you have?
Yes with ProjectWise, if the workspaces are set properly it launches the dgn with the workspace defined in ProjectWise.
