How to add the View Control short-cut on long right click to your workspace?
I tried the following and I still do not see the menu.
I am on version 10.03.00.43 OpenRoads Designer CONNECT Edition.
Answer:
The View Control uses a custom macro that must be part of your active workspace. In the
default installation, the macro is located at C:\ProgramData\Bentley\OpenRoads Designer
CE\Configuration\Organization-Civil\_Civil Default Standards -
Imperial\Macros\ViewSet.mvba. You can copy that to your workspace and set the
MS_VBAAUTOLOADPROJECTS configuration variable to load it automatically.
Created by Holly Herring
When: Fri, Jul 27 2018 10:00 AM
Revisions: 1
Comments: 0
