I tried the following and I still do not see the menu.
I am on version 10.03.00.43 OpenRoads Designer CONNECT Edition.
Answer:
The View Control uses a custom macro that must be part of your active workspace. In thedefault installation, the macro is located at C:\ProgramData\Bentley\OpenRoads DesignerCE\Configuration\Organization-Civil\_Civil Default Standards -Imperial\Macros\ViewSet.mvba. You can copy that to your workspace and set theMS_VBAAUTOLOADPROJECTS configuration variable to load it automatically.
Created by Holly HerringWhen: Fri, Jul 27 2018 10:00 AMRevisions: 1Comments: 0
Josh M - your other post in the Programming forum has a reply
https://communities.bentley.com/products/programming/civil_programming/f/civil_programming_forum/207500/viewset-mvba-to-display-pre-set-views
Duplicate posts in different forums lead to confusion.
