How do i export my DTM from inroads as the edited version and not the one it creates initially. ive made adjustments to the one i have but when i export it and then re import to check it looks like just as it did when i first made it.
This is a silly question, but I've done stranger things...After you've edited the DTM, do you Save it, then export it?
MaryB
MaryB said:This is a silly question, but I've done stranger things.
and.... new triangulations after export/import can do some strange things, too.
Frank
