Hi All
Has anyone gotten the Side Slope Annotation to work since Update 4 (2018 Release 2)?
I've followed the methodology in the video below, but it doesn't seem to apply at all (or even copy the annotation group form the library as a start):
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/37274/video-side-slope-annotation
I got this working in Update 2, but not again since Update 4.
I have the same problem with side slope annotations. I have checked the left and right offsets and they are sufficiently large. I also several times see the teeth of slope direction patterns are missing in the middle parts.
I also have the same problem. Have you any solution or suggestion about annotation preference?
I also find this tool very unreliable. Sometimes it creates gaps in annotation, sometimes it doesn't annotate at all... Very unpredictable.
I have the same problem, the tool does not work
Well okay, I had few more minutes to peek into those annotations again after the latest update (ORD 2020R2) and I think I've found biggest issue with those annotations so far:
Those annotations seek for features outside of theirs corridor!
On the picture we have 2 corridors - and we can clearly see that sideslope annotation from right corridor's shoulder edge is reaching left corridor's slope fill edge (2 on the picture). It then starts to annotate slope again from right corridor's shoulder to edge of fill (3 on the picture) and again stops when algorithm finds other corridor's edge of shoulder instead of edge of fill (4).
Still - there are situations when it works fine (1) and fails due to unknown reasons (5 - notice that it annotated it properly on short distance).
And beforehand someone tells - yes I know that corridors are not clipped to themselves, but what we also noticed - when you clip a corridor with anything via corridor clipping, that corridor's editing performance drastically drops.
How can I fill enhancement request for a prompt for user whether we want this annotation to include all corridors in dgn or only one corridor (for annotation to seek only inside selected / the corridor in which elements belong to)?
