Pattern files in OpenRoads Designer (.pat)
Hi
Where can I locate the pattern files in PowerCivil, and where can i put them to use in OpenRoads Designer?
Sigfús
  • For PowerCivil, the patterns are under the workspace folder (wherever that was installed) - 'WorkSpace\System\materials' - here is 'Bump' and 'Patterns' sub-folders, amongst others.
    For ORD, the configuration can have them under Organization, WorkSpace, or WorkSet - it does depend on how it is set up.
    Materials can be set on Feature Symbology, so that an asphalt road layer would be automatically rendered as Asphalt, for example.
Reply
