Good afternoon,
I am bringing in a survey input file (.txt) with a linked SMD file and the linear features are coming in with a 0.0083 Scale under the Line Style Parameters. How do elements get assigned a scale other than 1.0 by bringing in the file with the linked SMD? I looked in the SMD at one of the items in question, and I see the following:
<LinearFeature> <LinearFeatureToggle>1</LinearFeatureToggle> <LinearFeatureSymbology> <Level>Ug-water</Level> <Color>-1</Color> <Style type="0">2147483647</Style> <Weight>-1</Weight> </LinearFeatureSymbology> <LinearScaleOption>0</LinearScaleOption> <LinearScale>0</LinearScale> </LinearFeature>
It's been a little while since I've looked at this, so I'm not exactly sure what all those controls are (Type? ScaleOption? Scale?). I feel like it is a simple toggle somewhere, possibly not in the SMD, but I can't put my finger on it.
Thanks,Ken
See if this works
If working with GeoPak you may need to do a survey redraw to make the changes.
I checked the drawing scale and everything is set to 1.0. I know I can change the line style scale after the line work is already there, but I can't figure out why they are coming in at 0.0083 when I initially import the survey file.
What format are you using to import this linework? Looks like LandXML.
Yes, it is a linked XML file with the survey features.
Ken sorry to go back and forth. Maybe you can educate me? Are you using Geopak SS4? How are you linking a LandXML file to your dgn? Sounds like a great idea just never heard of doing it.
