Good afternoon,
I am bringing in a survey input file (.txt) with a linked SMD file and the linear features are coming in with a 0.0083 Scale under the Line Style Parameters. How do elements get assigned a scale other than 1.0 by bringing in the file with the linked SMD? I looked in the SMD at one of the items in question, and I see the following:
<LinearFeature> <LinearFeatureToggle>1</LinearFeatureToggle> <LinearFeatureSymbology> <Level>Ug-water</Level> <Color>-1</Color> <Style type="0">2147483647</Style> <Weight>-1</Weight> </LinearFeatureSymbology> <LinearScaleOption>0</LinearScaleOption> <LinearScale>0</LinearScale> </LinearFeature>
It's been a little while since I've looked at this, so I'm not exactly sure what all those controls are (Type? ScaleOption? Scale?). I feel like it is a simple toggle somewhere, possibly not in the SMD, but I can't put my finger on it.
Thanks,Ken
Could this be related to this configuration variable - This is from the Configuration Variables topic in the Civil Help File:
CIVIL_SURVEY_DISABLE_DIVIDE_BY_TWELVE
If set to a value of 1, this variable indicates that the sizes read from a GEOPAK SMD XML file should not be divided by 12 when linked into Survey Feature Definitions. (Applicable for GEOPAK XML SMD files in an English environment only)
I see where we are going now. Sometimes I'm a little slow on the uptake. Sorry for the confusion. Your discussing the Survey Features shown below.
I'm on track now.
Cliff
Chuck,
That is such a random variable, but I don't think that is what I need (tried it and didn't change anything). This problem started when I tried to reset our seed files that we are using (do to some issue that couldn't be tracked down). We took the latest Bentley seed file and modified it to our needs, but then it isn't handling the survey importing correctly now. It is only the line style scale that appears to be at the wrong scale. The text and the cells that come in are still ok.
Well, at this point, I need to bow out, as our setup is coming from the InRoads side of things. Sorry that I was not able to help.
