Hi
We currently draw profiles in MX using an input file and the Longdraw and Longline macro functions. We can use the pa=page option to create a paged layout, with the profile cut into sections and displayed over several sheets. But is it possible to stack the profiles vertically on a single sheet, like we can do with the sectdraw macro?
Yes, but it is a manual process i.e. you would have to define the profile 'window' position on the sheet, draw the first length required, and then overplot the second length in a new 'window' on the same sheet.
Answer Verified By: Stewart Hellen
Thanks Mark. I managed to get it working with the overplot option. Just a shame you cant automate it like you can with cross sections.
