I'm trying to place Labels with a text favorite to label station offsets, point coordinates etc, and I can't get the in-line leader to display even though it's checked on in the dimension style and has a value set. In the screen shot below, the top one was created using the place note command and text, bottom one is using label and text favorite. Anyone ran into this before?
Hi Patrick,
Would you mind sending screen captures of the Place Label settings in dialogue box and another with dimension style text settings?
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Sure, here they are
The first shot shows Plan Label with cell. Are you using text favorite or cell?
Have you tried modifying In-line leader under text setting?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/35103/drawing-production
I created a cell out of the text favorite, but it does the same thing whether or not I use the cell or text favorite when placing the label. I did adjust the in-line leader settings, and it didn't do anything.
I reproduced the issue and logged this defect in your behalf.
Hi Marcus, was wondering if you had an update on this defect?
I have this same problem. Any updates? Working in ORD CE ver.2020 R1U8.
