I recently installed Power InRoads V8i (SS4) 08.11.09.904 and began using.
The text editor preference I use is the Word Processor style.
Upon calling for the editor the 2nd, 3rd, and subsequent times in a session, the Word Processor appears in it's original size and location, although I have re-sized and moved it from it's original position every use. My issue is that I must reposition the dialog and open it up much larger (it's pretty small) every time. The previous PIR version and MicroStation typically do not behave that way, they behave in the MRU fashion.
What can I do to change this? Are old workspace preferences / .xml files in use and maybe non-compatible? I don't want to whack my prefs unless I really need to do it.
Pat
Can you back up your current preferences then whack them and try it?
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/33435/openroads-designer-connect-edition---wiki-articles-and-videos
Answer Verified By: Patrick Coyne
User: Arlington
Project: Cheatham
Interface: default
Beebe, do you mean the .xmls beginning with Arlington...
from this folder:
Volume in drive C is OS Volume Serial Number is AE78-9D37
Directory of C:\Users\pcoyne\AppData\Local\Bentley\PowerInRoads\8.11\TEh-iq2r2hhU8eGtqNpU8A\prefs
11/13/2018 09:46 AM <DIR> .11/13/2018 09:46 AM <DIR> ..11/02/2018 02:54 PM <DIR> civil11/01/2018 01:50 PM <DIR> civil_commands10/23/2018 09:33 AM <DIR> dwgdata11/15/2017 01:33 PM <DIR> surveytools11/12/2018 06:42 PM 22 tabschemes.csv11/13/2018 09:20 AM 404 webdropSettings.rsc11/13/2018 09:46 AM 0 beebe-list.txt11/09/2018 10:03 AM 28 dfltuser-PowerInRoads.cfg03/21/2018 04:13 PM 8,556 untitled-PowerInRoads-default.upf03/21/2018 04:13 PM 12,308 untitled-PowerInRoads.docking.xml03/21/2018 04:13 PM 2,686 untitled-PowerInRoads.untitled.default.GroupPanels.xml03/21/2018 04:13 PM 2,873 untitled-PowerInRoads.untitled.default.TaskNavigation.xml03/21/2018 04:13 PM 45,648 untitled-PowerInRoads.upf11/13/2018 09:20 AM 109,934 Arlington-PowerInRoads-default.upf11/13/2018 09:20 AM 59,151 Arlington-PowerInRoads.Cheatham.default.GroupPanels.xml11/13/2018 09:20 AM 1,136 Arlington-PowerInRoads.Cheatham.default.TaskNavigation.xml11/13/2018 09:20 AM 26,300 Arlington-PowerInRoads.docking.xml11/13/2018 09:20 AM 342,762 Arlington-PowerInRoads.upf02/12/2015 10:57 AM 1,576 RSSFeeds.xml09/19/2018 02:31 PM 1,071 Customize.xml11/06/2018 08:02 PM 340 examples-PowerInRoads-default.upf11/06/2018 08:02 PM 2,660 examples-PowerInRoads.upf 18 File(s) 617,455 bytes 6 Dir(s) 46,738,132,992 bytes free
I deleted the Arlington*.* files, and they were re-created. All is well. Thanks!
