showing survey comments. OpenRoads
I am importing survey points and when I do my field comments are not coming in. I assign the Note and that shows on the Text Import Wizard. however that does not come into the drawing.
is there any way I can get this to show on my plans. thanks for your help
If I add a description to the Element Information after it will show.
