Hi
Aqua checking in ORD is great, gives a very good presentation and save a lot time definitely.
However, to have it working the flow path need to be right in the first place.
In my model, the contours looks good and the flow arrows shows right, but the flow path just stop at nowhere.
You could see only one is right, the left of them are all wrong.
Same surface I tried it in Inroads / openroads / civil 3d, the flow path all wrong.
Anyone got any idea on this? I really want to use this function in ORD. Thanks.
Hi Alex
I think we'd probably need to see the data for this problem. It seems you are saying the flow path is wrong in Inroads and Civil 3d as well.
IS there anything out of the ordinary about the data where it is producing the wrong flow path ?
Simon Pegg
Bentley Civil Support
Thanks Simon. Just attached the files.
