I am using Open Roads in Microstation. Today I am working on profiles and it keeps crashing. Is crashing a typical problem for Open Roads? I have a new machine that I got specifically to handle Open Roads but today its been a bear. Any tips or things I can look at to make it perform better?
thanks
Brandon
I have found that going to your c:\users\your_username\appdata\local\bentley\openroadsdesigner\10.x.x.x\prefs and deleting everything seems to help a lot. You might want to save your *.upf file though (user preference file)
I used this with caution, aka. zipped the folder first, but this actually worked for me, so thank you!
Thank you Chris Neelin and Mark Russell. I was having the same issue but compressed the files in my C drive and then deleted them out of the folder and OpenRoads is working again.
