Is there a way to create a dimension line extending from a PVC to PVT so as to show the extent of a vertical curve in ORD?
I am trying to create an annotation group that does this but I cannot find a way to make this work.
This functionality has not been brought forward (yet) so I have created Enhancement 973756 PVC to PVT profile dimension line. It reads: As a user, I would like to be able to create a dimension line extending from a PVC to PVT in OpenRoads Designer CONNECT Edition as with InRoads SELECTseries 4.
Thank you for the response!
I may have spent more time than was necessary on it.
Has this functionality been incorporated in R4 of OpenRoads designer, or will it be coming in the next release, or...?
I did the same thing for a few hours a few weeks back until I could not see any logic in how it actually could be done. The issues- as I perceive them- would be the variable PVC/ PVT leader length lines as well as the variable VC horizontal distance. Everything else works well as the rest of the data can be assigned statically (as with horizontal alignment annotation).
Sanders:
It would appear that this functionality is still not available (ORD 2019, R1)?
Mark
