Is there a way to create a dimension line extending from a PVC to PVT so as to show the extent of a vertical curve in ORD?
I am trying to create an annotation group that does this but I cannot find a way to make this work.
This is something I expected to find in ORD 2019, R1 but did not see it there either.
Is everbody else manually drawing in dimension lines or do they have workarounds?
MJM
I expected to see it in 2019 R1 as well. There a dimension style "default" which is used to cover up the issue, as it were. But yes, we are manually drawing the dimension lines currently. The issues as I perceive them- see above- appear to remain with us currently.
Mark
Can luck w/ this? Are folks manually placing the dim lines for vertical curves? Mark, could you please elaborate on the "default" dimension style workaround? Thank you very much
actually, just as I typed the above questions I figured out the solution. you need to add component under-- Annotation Group > Profile > Drawing > and NOT under Annotation Group > Profile > Linear . Hope this helps
I'm very interested in how you did this. Can you post an example of what you came up with?
