Hi
Fill inside a shape are not visible in Named Boundary's model and sheet. How ever if the shape is copied into the sheet the fill become visible.
Fill in attributes are on...
Sigfús
So are we. Just in sheet and drawing models.
Katie, we ended up getting an answer from Bentley. If you are in your sheet model, open your reference dialog. Highlight the reference that contains the fill and then go to Properties>Presentation. It will open a "Reference Presentation" window that looks like "view attributes." You can then toggle on "fill". Hopefully this work for you
thanks, Jeremy
